The Philco service manual I linked to above has the Philco part numbers and some of the values.
The first link to PP tech has LOTS of good stuff in the menu on the right.
Under the "General" heading "How to decipher Philco resistor numbers" is a real Gem.
41-290 - by Todd Kaser - 03-27-2014, 08:36 AM
RE: 41-290 - by Eric Adams - 03-27-2014, 09:44 AM
RE: 41-290 - by TA Forbes - 03-27-2014, 09:45 AM
RE: 41-290 - by Todd Kaser - 03-27-2014, 09:50 AM
RE: 41-290 - by Eric Adams - 03-27-2014, 10:02 AM
RE: 41-290 - by TA Forbes - 03-27-2014, 10:35 AM
RE: 41-290 - by Todd Kaser - 03-27-2014, 10:47 AM
RE: 41-290 - by Joeztech - 03-28-2014, 07:26 AM
RE: 41-290 - by klondike98 - 03-28-2014, 08:11 AM
RE: 41-290 - by TA Forbes - 03-28-2014, 09:59 AM
RE: 41-290 - by Todd Kaser - 03-28-2014, 10:56 AM
RE: 41-290 - by lenmiller - 03-30-2014, 12:40 PM
RE: 41-290 - by Todd Kaser - 03-31-2014, 07:54 AM
RE: 41-290 - by K7Sparky - 04-03-2014, 05:38 PM
RE: 41-290 - by K7Sparky - 04-03-2014, 05:47 PM
RE: 41-290 - by K7Sparky - 04-03-2014, 09:21 PM
RE: 41-290 - by Raleigh - 04-03-2014, 10:06 PM
RE: 41-290 - by K7Sparky - 04-04-2014, 10:30 AM
There are currently 6955 online users. [Complete List]
» 1 Member(s) | 6954 Guest(s)
