Philco 39-30 Code 121 Push Buttons - Problem Found!
John Honeycutt
Thank you. Four of the 8 switches were NOT working. They would connect when you pushed the appropriate button, but when you pushed another button they would not disengage and that is why none of the pushbuttons would operate. I have removed the switch bank and unsoldered the coils and variable capacitors. There was a lot of rust in the radio and a friend is going to dip the whole switch bank in some anti-rust solution.
Thank you,
Oscar
nv3g
RE: Philco 39-30 Code 121 Push Buttons - by NV3G - 04-03-2014, 05:28 PM
RE: Philco 39-30 Code 121 Push Buttons -Problem Found - by NV3G - 04-04-2014, 02:49 PM
There are currently 4289 online users. [Complete List]
» 1 Member(s) | 4288 Guest(s)
