Zenith 7H822 Dial light?
Neon pilots complete with mounting stuff and resistor can be had for pennies. Bought a pack years ago and still have some. Use on 120 VAC, no heat, drill one hole and you're set.
Zenith 7H822 Dial light? - by Eric Adams - 03-31-2014, 05:41 PM
RE: Zenith 7H822 Dial light? - by BrendaAnnD - 03-31-2014, 07:08 PM
RE: Zenith 7H822 Dial light? - by Eric Adams - 03-31-2014, 07:17 PM
RE: Zenith 7H822 Dial light? - by morzh - 03-31-2014, 09:50 PM
RE: Zenith 7H822 Dial light? - by BrendaAnnD - 04-01-2014, 04:15 PM
RE: Zenith 7H822 Dial light? - by codefox1 - 04-04-2014, 03:20 PM
RE: Zenith 7H822 Dial light? - by Eric Adams - 04-04-2014, 05:32 PM
RE: Zenith 7H822 Dial light? - by morzh - 04-04-2014, 06:52 PM
