Just bought 2 90's a 70, an 89 and 2 19's
If anyone wants to know what happened to the unrelated comments in this thread regarding Dynakits, etc., they were moved here:
http://www.philcoradio.com/phorum/showth...p?tid=9223
RE: Just bought 2 90's a 70, an 89 and 2 19's - by Ron Ramirez - 04-04-2014, 09:57 PM
Philco 91 Tuning Condenser
