Will this transformer work in my 38-7?
Hi Brenda, you've probably seen this, but here are the specs for that transformer:
http://www.antiqueradios.com/forums/view...hp?t=32876
It looks very close, I can't find the exact B voltage of the 38-7.
RE: Will this transformer work in my 38-7? - by skyscraper - 04-04-2014, 10:26 PM
There are currently 6453 online users. [Complete List]
» 2 Member(s) | 6451 Guest(s)
