Ipod hook up
No;
If you were going to do it at all you would have to connect it through the audio circuitry, that is if you don't have a short range transmitter like a SSTRAN. If the set does not have a power transformer I would not do it at all, it's a safety hazard.
Ipod hook up - by ODPILOT - 04-05-2014, 06:30 PM
RE: Ipod hook up - by morzh - 04-05-2014, 06:52 PM
RE: Ipod hook up - by Arran - 04-06-2014, 01:27 AM
RE: Ipod hook up - by shaler78 - 04-06-2014, 01:45 AM
RE: Ipod hook up - by skyscraper - 04-06-2014, 01:14 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3493 online users. [Complete List]
» 1 Member(s) | 3492 Guest(s)
