My new 42-1012
Congratulations, Kevin! Icon_clap Icon_thumbup
The door linked above on eBay will not fit your cabinet. You will need one from a 42-1012 or a 41-610. Empty cabinets of those models pop up from time to time. Maybe one of you guys going to Kutztown could look for one of these for Kevin, or even save one from a cabinet destined for the Friday night flame?
My new 42-1012 - by 37silverstreak - 04-05-2014, 06:40 PM
RE: My new 42-1012 - by sam - 04-05-2014, 06:57 PM
RE: My new 42-1012 - by Radioroslyn - 04-05-2014, 07:10 PM
RE: My new 42-1012 - by gregb - 04-05-2014, 08:41 PM
RE: My new 42-1012 - by NostalgiaRadioTime - 04-05-2014, 09:32 PM
RE: My new 42-1012 - by Bill Kinghorn - 04-05-2014, 09:46 PM
RE: My new 42-1012 - by Bill Kinghorn - 04-05-2014, 09:54 PM
RE: My new 42-1012 - by Ron Ramirez - 04-06-2014, 07:47 AM
Philco 91 Tuning Condenser
