Ipod hook up
Use the phono lines.
It would be a god idea, both to match impedance and protect your ipod, to install an 8:1k ohm audio transformer. Use a switch to disconnect the phono when using the ipod.
Ipod hook up - by ODPILOT - 04-05-2014, 06:30 PM
RE: Ipod hook up - by morzh - 04-05-2014, 06:52 PM
RE: Ipod hook up - by Arran - 04-06-2014, 01:27 AM
RE: Ipod hook up - by shaler78 - 04-06-2014, 01:45 AM
RE: Ipod hook up - by skyscraper - 04-06-2014, 01:14 PM
