What order to do things?
You can grain fill first or stain to try to even the color before toning. Remember that if there is a logo decal you have to do it between toner and clear stages.
Dont lacquer and tone inside with no ventilation or you will get colored boogers and have a headache.Icon_crazy
What order to do things? - by PAradiogeek - 04-05-2014, 10:24 PM
RE: What order to do things? - by Eliot Ness - 04-05-2014, 11:49 PM
RE: What order to do things? - by PAradiogeek - 04-06-2014, 07:08 AM
RE: What order to do things? - by OldRestorer - 04-07-2014, 07:02 AM
RE: What order to do things? - by Jamie - 04-08-2014, 05:41 PM
RE: What order to do things? - by PAradiogeek - 04-09-2014, 02:52 PM
RE: What order to do things? - by Steve Davis - 04-09-2014, 05:20 PM
Philco 91 Tuning Condenser
There are currently 10151 online users. [Complete List]
» 3 Member(s) | 10148 Guest(s)
