  • 1 Vote(s) - 4 Average
1933 Cathedral Model 89B
By the way, When I bought this they said it was a 1936 but looking at the philco page it looks like the only one like it is a 1933. Can anyone tell me for sure if it is a 1933 or 1936? Thanks.
1933 Cathedral Model 89B - by Warren - 03-31-2014, 11:48 PM
RE: 1933 Cathedral Model 89B - by Steve Davis - 03-31-2014, 11:56 PM
RE: 1933 Cathedral Model 89B - by skyscraper - 04-01-2014, 12:35 AM
RE: 1933 Cathedral Model 89B - by PAradiogeek - 04-01-2014, 07:23 AM
RE: 1933 Cathedral Model 89B - by gregb - 04-01-2014, 05:52 PM
RE: 1933 Cathedral Model 89B - by Warren - 04-01-2014, 06:55 PM
RE: 1933 Cathedral Model 89B - by skyscraper - 04-01-2014, 07:04 PM
RE: 1933 Cathedral Model 89B - by Warren - 04-07-2014, 02:28 PM
RE: 1933 Cathedral Model 89B - by skyscraper - 04-07-2014, 02:32 PM
RE: 1933 Cathedral Model 89B - by Warren - 04-07-2014, 07:46 PM
RE: 1933 Cathedral Model 89B - by Ron Ramirez - 04-08-2014, 05:24 AM
RE: 1933 Cathedral Model 89B - by Warren - 04-08-2014, 02:45 PM
Philco 91 Tuning Condenser
