RCA-76 cap question
Just stick a 2400 ohm resistor in there or the closest you have for the time being and see if the radio works. It may work fine without it but if not then try fixing or replacing. Wont hurt anything to try.
Gregb
RCA-76 cap question - by Eric - 04-06-2014, 02:37 PM
RE: RCA-76 cap question - by Eliot Ness - 04-06-2014, 05:06 PM
RE: RCA-76 cap question - by Eric - 04-06-2014, 05:24 PM
RE: RCA-76 cap question - by Eliot Ness - 04-06-2014, 06:20 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 04:47 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 06:18 PM
RE: RCA-76 cap question - by gregb - 04-07-2014, 06:29 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 06:51 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 07:06 PM
RE: RCA-76 cap question - by gregb - 04-07-2014, 07:13 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 07:34 PM
RE: RCA-76 cap question - by Mondial - 04-07-2014, 10:09 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 02:19 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 04:24 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 05:32 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 06:11 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 07:07 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 08:55 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 08:44 AM
RE: RCA-76 cap question - by Eric - 04-09-2014, 09:18 AM
RE: RCA-76 cap question - by Mondial - 04-09-2014, 01:09 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 03:59 PM
RE: RCA-76 cap question - by Mondial - 04-09-2014, 06:09 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 06:49 PM
There are currently 3076 online users. [Complete List]
» 1 Member(s) | 3075 Guest(s)
