Philco 645 Hum-m-m-m
Agree about the electrolytics. Make sure that #s 58, 59, and the can that houses #s 51, 73, and 76 have been replaced.
Also check power resistor #64.
It is always a good idea to replace all paper and bakelite-block caps and check/replace resistors out of spec. Personally, I replace resistors greater than 10% out of spec.
Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 08:21 PM
RE: Philco 645 Hum-m-m-m - by gregb - 04-07-2014, 08:24 PM
RE: Philco 645 Hum-m-m-m - by Warren - 04-07-2014, 09:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 09:23 PM
RE: Philco 645 Hum-m-m-m - by Ron Ramirez - 04-08-2014, 05:31 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-08-2014, 10:10 AM
RE: Philco 645 Hum-m-m-m - by PAradiogeek - 04-08-2014, 11:16 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-08-2014, 01:26 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-09-2014, 12:54 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-09-2014, 10:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-09-2014, 01:45 PM
RE: Philco 645 Hum-m-m Fixed? - by Winky Dink - 04-12-2014, 10:43 AM
RE: Philco 645 Hum-m-m-m - by Steve Davis - 04-12-2014, 11:36 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-12-2014, 11:57 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-12-2014, 12:04 PM
RE: Philco 645 Hum-m-m-m - by BrendaAnnD - 04-12-2014, 04:18 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-13-2014, 05:14 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-13-2014, 09:28 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-14-2014, 01:29 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-14-2014, 08:23 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 04:28 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 10:30 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 04:24 PM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-16-2014, 04:43 PM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 05:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-17-2014, 04:54 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-17-2014, 08:54 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-18-2014, 01:08 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-02-2014, 11:20 PM
RE: Philco 645 Hum-m-m-m - by Arran - 07-03-2014, 12:21 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-03-2014, 01:53 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-03-2014, 09:45 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-04-2014, 12:37 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-05-2014, 11:09 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 01:57 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 08:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 09:30 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 10:16 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-07-2014, 08:04 PM
New member
Philco 630csx power cord
New member
There are currently 3375 online users. [Complete List]
» 4 Member(s) | 3371 Guest(s)
AvatarAvatarAvatarAvatar
