Philco 30 lowboy
Tonight work is to begin on this set! Only issue: the on-off knob somehow managed to take a serious set on the shaft and I broke some of the edge off the knob trying to get it back off. Icon_sad It was hard to get off before, but this time was really bad and I nearly tore the skin off my fingers trying to pop it back off the shaft. I'll have to find another. The knob is actually a bit defective, with an irregularly drilled or molded hole. My fingers really hurt from that thing...
Philco 30 lowboy - by Jayce - 11-11-2013, 08:09 PM
RE: Philco 30 lowboy - by jerryhawthorne - 11-11-2013, 10:23 PM
RE: Philco 30 lowboy - by Jayce - 02-17-2014, 05:52 PM
RE: Philco 30 lowboy - by jerryhawthorne - 02-17-2014, 06:14 PM
RE: Philco 30 lowboy - by tab10672 - 02-17-2014, 07:10 PM
RE: Philco 30 lowboy - by Jayce - 02-17-2014, 07:23 PM
RE: Philco 30 lowboy - by Radioroslyn - 02-17-2014, 11:59 PM
RE: Philco 30 lowboy - by Ron Ramirez - 02-18-2014, 06:51 AM
RE: Philco 30 lowboy - by TA Forbes - 02-18-2014, 12:35 PM
RE: Philco 30 lowboy - by Jayce - 02-18-2014, 05:54 PM
RE: Philco 30 lowboy - by Jayce - 04-08-2014, 02:57 PM
RE: Philco 30 lowboy - by TA Forbes - 04-09-2014, 10:40 AM
RE: Philco 30 lowboy - by Arran - 04-11-2014, 10:16 PM
Philco 91 Tuning Condenser
There are currently 8969 online users. [Complete List]
» 2 Member(s) | 8967 Guest(s)
