Philco 38-690 tweeter improvement
Ron Ramirez Wrote:Hi Dave
A properly restored 38-690 should deliver deep bass and noticeable treble - with the bass control set to max, and the Fidelity-Selectivity control set to maximum fidelity.
And, yes, a properly restored 38-690 will, most definitely, put any lower tube count set to shame, without a doubt.
I've owned one in the past...and had a few pass through here as repair jobs...so I know how they should sound; quite simply, SUPERB.
Thanks Ron,
I wish I had one to compare it to. If I turn the bass up all the way up and the treble all the way it does sound good. I just never thought one would typically play set with both adj to max.
Thanks Ron,
Dave
Re: Philco 38-690 tweeter improvement - by Syl - 07-25-2008, 11:16 AM
Re: Philco 38-690 tweeter improvement - by Syl - 07-25-2008, 09:19 PM
[No subject] - by Ron Ramirez - 07-25-2008, 10:39 PM
[No subject] - by wonderwrench - 07-25-2008, 10:52 PM
[No subject] - by Ron Ramirez - 07-25-2008, 11:49 PM
[No subject] - by Dave Slusarczyk - 07-25-2008, 11:53 PM
[No subject] - by wonderwrench - 07-26-2008, 12:06 AM
[No subject] - by Ron Ramirez - 07-26-2008, 12:06 AM
[No subject] - by Ron Ramirez - 07-26-2008, 12:13 AM
[No subject] - by Dave Slusarczyk - 07-26-2008, 12:59 AM
[No subject] - by BDM - 07-26-2008, 01:40 AM
[No subject] - by wonderwrench - 07-26-2008, 01:48 AM
[No subject] - by wonderwrench - 07-26-2008, 02:30 AM
[No subject] - by Syl - 07-26-2008, 09:33 AM
[No subject] - by Ron Ramirez - 07-26-2008, 10:20 AM
[No subject] - by Syl - 07-26-2008, 12:52 PM
[No subject] - by Dave Slusarczyk - 07-26-2008, 04:33 PM
[No subject] - by wonderwrench - 07-26-2008, 04:47 PM
[No subject] - by wonderwrench - 07-26-2008, 04:53 PM
[No subject] - by Ron Ramirez - 07-26-2008, 05:40 PM
[No subject] - by Syl - 07-26-2008, 05:51 PM
[No subject] - by Syl - 07-26-2008, 05:55 PM
[No subject] - by Dave Slusarczyk - 07-26-2008, 06:50 PM
[No subject] - by Syl - 07-26-2008, 08:17 PM
[No subject] - by Dave Slusarczyk - 07-26-2008, 10:26 PM
[No subject] - by Syl - 07-27-2008, 12:11 AM
[No subject] - by Dave Slusarczyk - 07-27-2008, 02:02 PM
[No subject] - by Terry Judkins - 07-27-2008, 06:59 PM
[No subject] - by wonderwrench - 07-27-2008, 07:11 PM
[No subject] - by Dave Slusarczyk - 07-27-2008, 07:53 PM
[No subject] - by wonderwrench - 07-27-2008, 10:00 PM
[No subject] - by Syl - 07-28-2008, 11:21 AM
[No subject] - by Dave Slusarczyk - 07-28-2008, 06:10 PM
[No subject] - by BDM - 07-28-2008, 06:17 PM
[No subject] - by Ron Ramirez - 07-28-2008, 06:59 PM
[No subject] - by Dave Slusarczyk - 07-28-2008, 07:12 PM
[No subject] - by Syl - 07-28-2008, 09:33 PM
