RCA-76 cap question
I will check L17 to see what I get.
But also came across this Hammond choke coil #155c 60H 2700 ohms I think this might work for L14?
RCA-76 cap question - by Eric - 04-06-2014, 02:37 PM
RE: RCA-76 cap question - by Eliot Ness - 04-06-2014, 05:06 PM
RE: RCA-76 cap question - by Eric - 04-06-2014, 05:24 PM
RE: RCA-76 cap question - by Eliot Ness - 04-06-2014, 06:20 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 04:47 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 06:18 PM
RE: RCA-76 cap question - by gregb - 04-07-2014, 06:29 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 06:51 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 07:06 PM
RE: RCA-76 cap question - by gregb - 04-07-2014, 07:13 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 07:34 PM
RE: RCA-76 cap question - by Mondial - 04-07-2014, 10:09 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 02:19 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 04:24 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 05:32 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 06:11 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 07:07 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 08:55 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 08:44 AM
RE: RCA-76 cap question - by Eric - 04-09-2014, 09:18 AM
RE: RCA-76 cap question - by Mondial - 04-09-2014, 01:09 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 03:59 PM
RE: RCA-76 cap question - by Mondial - 04-09-2014, 06:09 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 06:49 PM
