Philco 645K Refinish
You are right, as long as you did not do anything super-permanent or nasty (like polyurethane) it is all correctable.
But kep in mind the saying: "No solution is more permanent than the temporary one" Icon_smile
You get accustomed to it and you live it in place, so if you truly intend to re-do it at some point, do it as soon as you can Icon_lol
Philco 645K Refinish - by Winky Dink - 03-24-2014, 12:32 PM
RE: Philco 645K Refinish - by OldRestorer - 03-24-2014, 06:23 PM
RE: Philco 645K Refinish - by Ronin61 - 03-29-2014, 01:45 AM
RE: Philco 645K Refinish - by Jamie - 03-30-2014, 08:31 AM
RE: Philco 645K Refinish - by Winky Dink - 04-07-2014, 10:09 PM
RE: Philco 645K Refinish - by OldRestorer - 04-08-2014, 07:20 AM
RE: Philco 645K Refinish - by morzh - 04-08-2014, 10:13 AM
RE: Philco 645K Refinish - by TA Forbes - 04-08-2014, 01:29 PM
RE: Philco 645K Refinish - by Winky Dink - 04-09-2014, 12:42 AM
RE: Philco 645K Refinish - by morzh - 04-09-2014, 09:25 AM
RE: Philco 645K Refinish - by Eliot Ness - 04-10-2014, 10:05 AM
RE: Philco 645K Refinish - by gregb - 04-10-2014, 11:05 AM
RE: Philco 645K Refinish - by Winky Dink - 04-13-2014, 04:17 PM
Philco 91 Tuning Condenser
There are currently 9079 online users. [Complete List]
» 2 Member(s) | 9077 Guest(s)
