Need a Kutztown pickup and forward
Sorry Brenda, but I don't think I'll be going this spring. Would be a problem none the less. Last year I went and saw several radios I would liked to have purchased. However, I fly in, and trying to get these old sets past security at the airport can be a little challenging. I could check them as baggage, but having been a baggage handler I know what they would look like by the time I got them back to Detroit! Take care, Gary.
RE: Need a Kutztown pickup and forward - by GarySP - 04-09-2014, 10:40 AM
RE: Need a Kutztown pickup and forward - by morzh - 04-12-2014, 10:01 PM
Philco 91 Tuning Condenser
There are currently 8760 online users. [Complete List]
» 2 Member(s) | 8758 Guest(s)
