RCA-76 cap question
yes went from each side of the coil to ground and got 0vdc
also just want to verify c38 pos goes to ground and the neg goes to the center tap
I'm going to order that choke coil
RCA-76 cap question - by Eric - 04-06-2014, 02:37 PM
RE: RCA-76 cap question - by Eliot Ness - 04-06-2014, 05:06 PM
RE: RCA-76 cap question - by Eric - 04-06-2014, 05:24 PM
RE: RCA-76 cap question - by Eliot Ness - 04-06-2014, 06:20 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 04:47 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 06:18 PM
RE: RCA-76 cap question - by gregb - 04-07-2014, 06:29 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 06:51 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 07:06 PM
RE: RCA-76 cap question - by gregb - 04-07-2014, 07:13 PM
RE: RCA-76 cap question - by Eric - 04-07-2014, 07:34 PM
RE: RCA-76 cap question - by Mondial - 04-07-2014, 10:09 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 02:19 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 04:24 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 05:32 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 06:11 PM
RE: RCA-76 cap question - by Eric - 04-08-2014, 07:07 PM
RE: RCA-76 cap question - by Mondial - 04-08-2014, 08:55 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 08:44 AM
RE: RCA-76 cap question - by Eric - 04-09-2014, 09:18 AM
RE: RCA-76 cap question - by Mondial - 04-09-2014, 01:09 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 03:59 PM
RE: RCA-76 cap question - by Mondial - 04-09-2014, 06:09 PM
RE: RCA-76 cap question - by Eric - 04-09-2014, 06:49 PM
