freed eisemann model 51
Interesting.....
Not a well documented manufacturer here in the USA.
Sounds like a 40s set. Can you provide us some photos?
freed eisemann model 51 - by murf - 04-10-2014, 07:52 PM
RE: freed eisemann model 51 - by TA Forbes - 04-11-2014, 07:55 AM
