Found a Fisher turntable
If you want a Fisher turntable, keep your eyes open for a The Fisher 401 or 502, which are rebranded Perpetuum Ebner changers. From what I have read, the P-E changer is actually a very good quality unit. The BSR is okay if you like wow, flutter, and odd microphonic noises coming through your speakers while you are playing your records. I thought BSR was okay, years ago, until I acquired a second hand Technics direct drive turntable. I think it was an SL-D3. Wow, what a difference. I wish I still had it.
I thought about getting a 401 or 502, but I ended up with a nice Realistic LAB-440 direct drive turntable which works very well. Maybe not quite as nice as the Technics, but it will do. Icon_smile
Found a Fisher turntable - by captainslack - 04-11-2014, 01:51 PM
RE: Found a Fisher turntable - by Ron Ramirez - 04-11-2014, 07:09 PM
RE: Found a Fisher turntable - by Ron Ramirez - 04-11-2014, 07:21 PM
RE: Found a Fisher turntable - by captainslack - 04-11-2014, 10:58 PM
RE: Found a Fisher turntable - by Arran - 04-12-2014, 12:16 AM
RE: Found a Fisher turntable - by captainslack - 04-12-2014, 06:09 PM
