Philco 645 Hum-m-m-m
Thanks. I will experiment with various C58/C59 values to find the lowest combination that kills the hum. Also will recheck the caps and resistors you mention. All caps have been replaced except micas, and all resistors more than 10% out of spec were replaced. I've checked C50,51,62 and R48,49 numerous times, but I may try replacing them one at a time in case something is failing under load.
Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 08:21 PM
RE: Philco 645 Hum-m-m-m - by gregb - 04-07-2014, 08:24 PM
RE: Philco 645 Hum-m-m-m - by Warren - 04-07-2014, 09:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-07-2014, 09:23 PM
RE: Philco 645 Hum-m-m-m - by Ron Ramirez - 04-08-2014, 05:31 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-08-2014, 10:10 AM
RE: Philco 645 Hum-m-m-m - by PAradiogeek - 04-08-2014, 11:16 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-08-2014, 01:26 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-09-2014, 12:54 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-09-2014, 10:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-09-2014, 01:45 PM
RE: Philco 645 Hum-m-m Fixed? - by Winky Dink - 04-12-2014, 10:43 AM
RE: Philco 645 Hum-m-m-m - by Steve Davis - 04-12-2014, 11:36 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-12-2014, 11:57 AM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-12-2014, 12:04 PM
RE: Philco 645 Hum-m-m-m - by BrendaAnnD - 04-12-2014, 04:18 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-13-2014, 05:14 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-13-2014, 09:28 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-14-2014, 01:29 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-14-2014, 08:23 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 04:28 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 10:30 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-16-2014, 04:24 PM
RE: Philco 645 Hum-m-m-m - by TA Forbes - 04-16-2014, 04:43 PM
RE: Philco 645 Hum-m-m-m - by morzh - 04-16-2014, 05:05 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-17-2014, 04:54 AM
RE: Philco 645 Hum-m-m-m - by morzh - 04-17-2014, 08:54 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 04-18-2014, 01:08 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-02-2014, 11:20 PM
RE: Philco 645 Hum-m-m-m - by Arran - 07-03-2014, 12:21 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-03-2014, 01:53 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-03-2014, 09:45 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-04-2014, 12:37 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-05-2014, 11:09 PM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 01:57 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 08:58 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-06-2014, 09:30 AM
RE: Philco 645 Hum-m-m-m - by morzh - 07-06-2014, 10:16 AM
RE: Philco 645 Hum-m-m-m - by Winky Dink - 07-07-2014, 08:04 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4124 online users. [Complete List]
» 1 Member(s) | 4123 Guest(s)
