Need a Kutztown pickup and forward
Mike,
No, he wasn't interested in shipping the set at all, because of the size, likelihood of damage, etc.
RE: Need a Kutztown pickup and forward - by morzh - 04-12-2014, 10:01 PM
RE: Need a Kutztown pickup and forward - by BrendaAnnD - 04-12-2014, 11:42 PM
Philco 91 Tuning Condenser
