How to clean my Model 71 escutcheon?
Kleen strip will remove the paint without removing the tarnish. I personally like to shine them a little if I am refinishing the cabinet as to look like it was just made and not having been alive in the early thirties I dont know what it would have looked like when new but I'm sure philco didnt purposely tarnish new brass.
RE: How to clean my Model 71 escutcheon? - by tab10672 - 04-13-2014, 12:58 AM
Philco 91 Tuning Condenser
There are currently 8834 online users. [Complete List]
» 3 Member(s) | 8831 Guest(s)
