Philco 645K Refinish
Thanks for showing me the thread on chassis stamps. I've previously tried several unsuccessful ways to transfer inkjet print to metal chassis--even tried using fabric transfer paper. I didn't have any freezer paper, so I tried this with waxed paper. It makes a good facsimile of a rubber stamp.
[Image: https://lh6.googleusercontent.com/-klC5q...520100.jpg]
I'm sure that with the right transfer paper, it could reproduce higher-quality print, such as the printed part numbers on top-of-chassis chassis components.
As for the dark-colored trim on the 645X cabinet: It looks better in real life than in the photos, but I feel that it still doesn't look right, and I'll redo it this fall.
Philco 645K Refinish - by Winky Dink - 03-24-2014, 12:32 PM
RE: Philco 645K Refinish - by OldRestorer - 03-24-2014, 06:23 PM
RE: Philco 645K Refinish - by Ronin61 - 03-29-2014, 01:45 AM
RE: Philco 645K Refinish - by Jamie - 03-30-2014, 08:31 AM
RE: Philco 645K Refinish - by Winky Dink - 04-07-2014, 10:09 PM
RE: Philco 645K Refinish - by OldRestorer - 04-08-2014, 07:20 AM
RE: Philco 645K Refinish - by morzh - 04-08-2014, 10:13 AM
RE: Philco 645K Refinish - by TA Forbes - 04-08-2014, 01:29 PM
RE: Philco 645K Refinish - by Winky Dink - 04-09-2014, 12:42 AM
RE: Philco 645K Refinish - by morzh - 04-09-2014, 09:25 AM
RE: Philco 645K Refinish - by Eliot Ness - 04-10-2014, 10:05 AM
RE: Philco 645K Refinish - by gregb - 04-10-2014, 11:05 AM
RE: Philco 645K Refinish - by Winky Dink - 04-13-2014, 04:17 PM
Philco 91 Tuning Condenser
There are currently 10218 online users. [Complete List]
» 3 Member(s) | 10215 Guest(s)
