Blue Tape, Grrrrr
I had better luck with simple masking tape rather than the painters tape. If you only have some tape residue left afterwards some mineral spirits should clean it up.
Blue Tape, Grrrrr - by PAradiogeek - 04-13-2014, 09:28 PM
RE: Blue Tape, Grrrrr - by morzh - 04-13-2014, 09:33 PM
RE: Blue Tape, Grrrrr - by PAradiogeek - 04-13-2014, 09:36 PM
RE: Blue Tape, Grrrrr - by morzh - 04-13-2014, 09:37 PM
RE: Blue Tape, Grrrrr - by PAradiogeek - 04-13-2014, 09:44 PM
RE: Blue Tape, Grrrrr - by OldRestorer - 04-13-2014, 09:47 PM
RE: Blue Tape, Grrrrr - by PAradiogeek - 04-13-2014, 09:54 PM
RE: Blue Tape, Grrrrr - by Warren - 04-14-2014, 12:15 AM
RE: Blue Tape, Grrrrr - by PAradiogeek - 04-14-2014, 09:30 AM
RE: Blue Tape, Grrrrr - by Geoff - 04-14-2014, 12:30 PM
RE: Blue Tape, Grrrrr - by Steve Davis - 04-14-2014, 01:05 PM
RE: Blue Tape, Grrrrr - by Ron Ramirez - 04-14-2014, 01:46 PM
RE: Blue Tape, Grrrrr - by PAradiogeek - 04-14-2014, 01:48 PM
RE: Blue Tape, Grrrrr - by Steve Davis - 04-14-2014, 02:01 PM
RE: Blue Tape, Grrrrr - by Ron Ramirez - 04-14-2014, 02:04 PM
RE: Blue Tape, Grrrrr - by PAradiogeek - 04-14-2014, 02:05 PM
RE: Blue Tape, Grrrrr - by Art Hoch - 04-15-2014, 05:30 PM
RE: Blue Tape, Grrrrr - by Warren - 04-15-2014, 05:58 PM
RE: Blue Tape, Grrrrr - by TimC - 04-15-2014, 08:54 PM
RE: Blue Tape, Grrrrr - by Arran - 04-16-2014, 01:13 AM
Philco 91 Tuning Condenser
There are currently 8891 online users. [Complete List]
» 1 Member(s) | 8890 Guest(s)
