Philco Power Transformers 3752, 4446, 4938 ???
Hello Chuck
I found that the 4446 camee out of a Philco 90 with 2 45 in PP
That is what I was hoping to find.
Looks like I have to have Heyborer make me one
2.5 v @ around 12-13 A
Thank you for checking
RE: Philco Power Transformers 3752, 4446, 4938 ??? - by joybird - 04-14-2014, 09:45 AM
Philco 91 Tuning Condenser
There are currently 4430 online users. [Complete List]
» 1 Member(s) | 4429 Guest(s)
