New Philco
Surround sound, 1930s style (40s?). Nice set!
New Philco - by gregb - 04-13-2014, 11:58 PM
RE: New Philco - by morzh - 04-14-2014, 12:02 AM
RE: New Philco - by OldRestorer - 04-14-2014, 07:18 AM
RE: New Philco - by PAradiogeek - 04-14-2014, 12:29 PM
RE: New Philco - by TA Forbes - 04-14-2014, 12:30 PM
RE: New Philco - by gregb - 04-14-2014, 12:33 PM
RE: New Philco - by Ron Ramirez - 04-14-2014, 02:00 PM
RE: New Philco - by gregb - 04-14-2014, 02:39 PM
RE: New Philco - by Ron Ramirez - 04-14-2014, 02:51 PM
RE: New Philco - by gregb - 04-14-2014, 03:20 PM
RE: New Philco - by Jayce - 04-14-2014, 04:33 PM
RE: New Philco - by Eliot Ness - 04-14-2014, 11:49 PM
RE: New Philco - by gregb - 04-14-2014, 11:56 PM
RE: New Philco - by PhilcoJohn - 04-17-2014, 06:42 PM
RE: New Philco - by klondike98 - 04-19-2014, 12:10 PM
RE: New Philco - by Jamie - 04-19-2014, 04:38 PM
RE: New Philco - by gregb - 04-19-2014, 05:29 PM
RE: New Philco - by fegravel - 04-21-2014, 10:15 PM
Philco 91 Tuning Condenser
