Philco 84B Restoration Chronicles DONE
thanks Geoff,
I finished her yesterday,
toned the grill cloth and put her back together. Sorry for the crappy pics.
still not happy with the finish but it aint half as bad as the electrical. gonna have to pay someone to align and do all the work I cant. it is a bit disheartening, Icon_thumbdown
RE: Philco 84B Restoration Chronicles - by morzh - 04-08-2014, 10:31 PM
RE: Philco 84B Restoration Chronicles - by Geoff - 04-14-2014, 12:36 PM
RE: Philco 84B Restoration Chronicles - by OldRestorer - 04-14-2014, 03:24 PM
