Zenith IF adjustment strangeness
Thanks Randal. Interesting tech notes there. Here are a few links to them.
http://www.hvra.org/znthshop.htm
http://www.hvra.org/polarize.htm
Also, a nice photo section
http://www.antique-radios.net/radpix2/radpix2.html
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Zenith IF adjustment strangeness - by BDM - 07-26-2008, 01:52 AM
[No subject] - by exray - 07-26-2008, 06:16 AM
[No subject] - by etech - 07-26-2008, 10:01 AM
[No subject] - by BDM - 07-26-2008, 08:40 PM
[No subject] - by etech - 07-26-2008, 09:46 PM
[No subject] - by BDM - 07-27-2008, 12:22 AM
RE: Zenith IF adjustment strangeness - by BDM - 07-27-2008, 02:27 AM
[No subject] - by Texasrocker - 07-27-2008, 02:35 AM
[No subject] - by etech - 07-27-2008, 09:02 PM
[No subject] - by BDM - 07-27-2008, 09:10 PM
[No subject] - by Doug Houston - 08-09-2008, 10:01 PM
There are currently 8933 online users. [Complete List]
» 1 Member(s) | 8932 Guest(s)
