Replacing a Field Coil with a PM Speaker - Please Help
BDI1976, is the audio output transformer part of your original Philco speaker assembly? If it is, then the schematic makes more sense to me. On some older Philcos, the output transformer, the field coil, and the voice coil are all part of the speaker assembly. Later Philcos have the output transformer inside or on top of the chassis.
Before you decide exactly how to make the connections to install your modern PM speaker, you have to know if the output connector is attached to the chassis or if it is attached to the speaker assembly.
I think the little "V" shaped notations on the schematic represent connectors. If I'm interpreting this right, then there is a long bundle of 3 wires connecting the chassis with the speaker. The colors of those 3 wires are not specified on the schematic. The colored wires specified in the schematic are part of the speaker assembly, not the wires from the chassis.
The connector lines up so that the green wire on the speaker assembly connects to the plate of the 42 tube, the green/white wire of the speaker assembly connects to the + of the 8uF cap, and the white wire of the speaker assembly connects to the + side of the 4uF capacitor. All other connections are internal to the speaker assembly.
Now, if the output transformer is mounted on the speaker assembly, then you have to mount it or a replacement somewhere else.
Let me know if the transformer is mounted on the speaker (or post a picture), and then we can go from there. I think I can be very specific about which wires go where once I know that.
John Honeycutt
RE: Replacing a Field Coil with a PM Speaker - Please Help - by Raleigh - 04-15-2014, 08:49 PM
What should I offer?
I think you have a chance at purchasing a 48-1286, based on the cabinet hardware. Only 8700 were produced, so it is a r...GarySP — 02:28 PM
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264. In any ...morzh — 12:44 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
