Joltin' Joe with his Philco
Those handles had a steel strap sewn between the two pieces of leather to support the weight. No joke. You can feel it with a magnet. It needed it, too. My bathroom scale says the radio with battery weighs 14 1/4 pounds. The battery alone was 5 1/2 pounds.
John Honeycutt
Joltin' Joe with his Philco - by Raleigh - 04-15-2014, 03:31 PM
RE: Joltin' Joe with his Philco - by TimC - 04-15-2014, 08:41 PM
RE: Joltin' Joe with his Philco - by Raleigh - 04-16-2014, 10:16 AM
RE: Joltin' Joe with his Philco - by TA Forbes - 04-16-2014, 04:37 PM
RE: Joltin' Joe with his Philco - by WyTex - 04-16-2014, 08:10 PM
RE: Joltin' Joe with his Philco - by vinzer - 04-16-2014, 09:07 PM
RE: Joltin' Joe with his Philco - by Radioroslyn - 04-17-2014, 06:51 AM
RE: Joltin' Joe with his Philco - by Raleigh - 04-17-2014, 10:36 AM
Philco 91 Tuning Condenser
There are currently 5462 online users. [Complete List]
» 3 Member(s) | 5459 Guest(s)
