650X dial drive removel.
How does one go about removing the dial drive assembly on a 650?
I'd like to clean and re lube the assembly as it's dry and ruff.
I see this guide at http://www.philcorepairbench.com/tips/svctip14.htm
I can't get the assembly past the semi circular wire it drives. I sure do not want to break any thing.
thanks
Bill
It's not what you don't know that hurts you it's what you know that's not so.
650X dial drive removel. - by wonderwrench - 07-27-2008, 08:28 PM
[No subject] - by Ron Ramirez - 07-27-2008, 11:46 PM
[No subject] - by BDM - 07-28-2008, 11:49 PM
[No subject] - by etech - 07-29-2008, 01:05 AM
[No subject] - by wonderwrench - 07-30-2008, 02:18 PM
[No subject] - by BDM - 07-30-2008, 05:49 PM
[No subject] - by BDM - 07-30-2008, 09:21 PM
[No subject] - by wonderwrench - 07-31-2008, 05:01 PM
[No subject] - by BDM - 07-31-2008, 05:20 PM
[No subject] - by wonderwrench - 07-31-2008, 09:30 PM
There are currently 10115 online users. [Complete List]
» 2 Member(s) | 10113 Guest(s)
