Philco 90 No Spkr or Output Transf.
I just checked the 80 Rect datasheet again and it lists max peak transient plate current at 2.2 amps.
In my simulator I get about 890mA peak plate current for the very first cycle of the 120 Hz. So, I think I'm OK. I have made some assumptions about the 80 Rect. model which I think are close, I modeled it as two 1N4007 diodes each in series with 300 ohms. Even if I'm off by a factor of two on the 300 Ohms I'm still OK.
Also, the 1.5K resistors seem to really isolate the later two Caps from the startup transient. Making them 10uF instead of 22uF hardly
changed the first cycle peak current at all.
This makes sense as the dominant factor is charging the input cap
(here 10uF directly from the 80 rectifier output). Initially that cap
looks like a dead short so the current is limited by the impedance
of the 80 rect. plus whatever transformer resistance and leakage inductance there is.
The two C's on the other side of the 1.5Ks don't seem to factor
in at all to that first cycle peak current surge.
Herb S.
Philco 90 No Spkr or Output Transf. - by hsusmann - 04-16-2014, 04:01 PM
RE: Philco 90 No Spkr or Output Transf. - by hsusmann - 04-16-2014, 05:21 PM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
