Capacitor replacement question
I have my Crosley open and am replacing the capacitors. I have a few of the caps that have 2 leads and a center wire.
I want to make sure I am rewiring it correctly so here is my question:
How do I wire the new cap into this spot
I have done this before but cant remember 100%. Dont I just use 2 caps with both negatives connected to the terminal where the center wire was?
Thanks for any help!
Kirk
Capacitor replacement question - by OldRestorer - 04-17-2014, 02:16 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 03:20 PM
RE: Capacitor replacement question - by exray - 04-17-2014, 05:58 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 07:10 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 09:33 PM
RE: Capacitor replacement question - by exray - 04-18-2014, 05:57 AM
RE: Capacitor replacement question - by tab10672 - 04-18-2014, 09:26 AM
RE: Capacitor replacement question - by bfrohwein - 04-18-2014, 12:34 PM
RE: Capacitor replacement question - by tab10672 - 04-18-2014, 04:07 PM
RE: Capacitor replacement question - by Jamie - 04-20-2014, 08:49 AM
