41-280 Escutcheon brass strip
Yep letters are recessed.
Glad to know about the change in Brasso. What is on hand is still old metal can.
I will try a bit of the Amway first as I have it and shoot a pix. Had great luck on chrome on old Honda and removing the blue rings left on front after cleaning SS revolver cylinder - high intensity cartridges same as top rifle pressures.
41-280 Escutcheon brass strip - by K7Sparky - 04-16-2014, 06:32 PM
RE: 41-280 Escutcheon brass strip - by Eliot Ness - 04-16-2014, 06:58 PM
RE: 41-280 Escutcheon brass strip - by K7Sparky - 04-17-2014, 10:12 AM
RE: 41-280 Escutcheon brass strip - by Eliot Ness - 04-17-2014, 03:45 PM
RE: 41-280 Escutcheon brass strip - by Jamie - 04-17-2014, 06:19 PM
RE: 41-280 Escutcheon brass strip - by K7Sparky - 04-17-2014, 06:54 PM
RE: 41-280 Escutcheon brass strip - by Eliot Ness - 04-17-2014, 08:55 PM
RE: 41-280 Escutcheon brass strip - by K7Sparky - 04-18-2014, 05:37 PM
RE: 41-280 Escutcheon brass strip - by Jamie - 04-20-2014, 08:59 AM
RE: 41-280 Escutcheon brass strip - by klondike98 - 04-20-2014, 11:08 AM
RE: 41-280 Escutcheon brass strip - by Eliot Ness - 04-20-2014, 02:27 PM
