116X Help
One more thing you might try is changing the 78 RF and 1st IF tubes. If one of these has excessive gas it will cause positive grid current, partially cancelling out the negative AVC voltage. I once had this problem with my 89, where the AVC never went over -4 or -5 volts. With no antenna connected, my AVC line was slightly positive, and only went negative on a strong signal.
How does your shadow meter seem to operate? Do you get good deflection and a narrow shadow with a strong signal?
116X Help - by gregb - 04-12-2014, 04:42 PM
RE: 116X Help - by morzh - 04-12-2014, 07:06 PM
RE: 116X Help - by gregb - 04-12-2014, 07:49 PM
RE: 116X Help - by TA Forbes - 04-13-2014, 10:13 AM
RE: 116X Help - by gregb - 04-13-2014, 11:41 AM
RE: 116X Help - by TA Forbes - 04-13-2014, 04:19 PM
RE: 116X Help - by gregb - 04-13-2014, 07:21 PM
RE: 116X Help - by gregb - 04-14-2014, 11:15 AM
RE: 116X Help - by TA Forbes - 04-14-2014, 12:40 PM
RE: 116X Help - by gregb - 04-14-2014, 05:25 PM
RE: 116X Help - by TA Forbes - 04-14-2014, 11:42 PM
RE: 116X Help - by gregb - 04-14-2014, 11:52 PM
RE: 116X Help - by gregb - 04-15-2014, 10:12 AM
RE: 116X Help - by gregb - 04-16-2014, 09:06 PM
RE: 116X Help - by gregb - 04-16-2014, 10:07 PM
RE: 116X Help - by Mondial - 04-16-2014, 11:20 PM
RE: 116X Help - by gregb - 04-17-2014, 09:12 AM
RE: 116X Help - by Mondial - 04-17-2014, 11:19 AM
RE: 116X Help - by gregb - 04-17-2014, 12:54 PM
RE: 116X Help - by Mondial - 04-17-2014, 03:38 PM
RE: 116X Help - by gregb - 04-17-2014, 04:43 PM
RE: 116X Help - by Mondial - 04-17-2014, 08:15 PM
RE: 116X Help - by gregb - 04-17-2014, 08:28 PM
RE: 116X Help - by gregb - 04-17-2014, 10:30 PM
RE: 116X Help - by bfrohwein - 04-18-2014, 12:22 PM
RE: 116X Help - by gregb - 04-18-2014, 01:03 PM
RE: 116X Help - by bfrohwein - 04-18-2014, 02:25 PM
RE: 116X Help - by gregb - 04-18-2014, 02:40 PM
RE: 116X Help - by bfrohwein - 04-23-2014, 10:21 AM
[split] 37-9 Magnetic Tuning Vernier Issue...
This thread has been split from Introduce Yourself to Philco Electronic Restoration for chassis repair questions and adv...GarySP — 03:08 PM
New member...
Hello Howard Woodward, and welcome to the Phorum! Not to scare you, but you are opening a potential Pandora's Box. In ...GarySP — 02:20 PM
Hi fellas and thanks for the helpful replies.  First, let me apologize for the title typo.  It's a "37-9" and ...HowardWoodard — 02:07 PM
New member...
Hi back at you and thanks for your note, it was both welcoming and helpful. I thought 37-9 was the model number.  Is ...HowardWoodard — 12:48 PM
I have noticed that the AVC line in some pre-war Philcos is connected to the suppressor grid, as well as the control gri...RodB — 10:47 AM
39-7 Magnetic Tuning Vernier Issue...
Hi Howard, Is this the same radio chassis that you list in your "New Member" post? If so, we need to comb...MrFixr55 — 10:46 AM
New member...
Hi Howard, First off, welcome to the Philco Phorum!  Lots of Phine Phriendly Pholks Phull of Philco Phacts and Phun in...MrFixr55 — 10:14 AM
philco 91 detector transformer
Hi Benny, There is an article in the Phorum's Philco Library on rewinding coils, however, the 91 is not listed.  The 1s...MrFixr55 — 09:14 AM
Not only would it not make sense for a suppressor grid to be tied to the (signal) grid, but both would be tied to ground...Arran — 06:08 AM
Howard, First thing you can do is to soak this unit in some lacquer thinner . What happens is the old greese gums up ...radiorich — 01:23 AM
