Capacitor replacement question
In the example shown the case of the can is connected to chassis ground. Sometimes they will be mounted on a disc of insulating material and the negative connections will be made via a ring on the bottom of the chassis.
On those dual wax caps they often have different values on either size. Use the schematic.
Capacitor replacement question - by OldRestorer - 04-17-2014, 02:16 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 03:20 PM
RE: Capacitor replacement question - by exray - 04-17-2014, 05:58 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 07:10 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 09:33 PM
RE: Capacitor replacement question - by exray - 04-18-2014, 05:57 AM
RE: Capacitor replacement question - by tab10672 - 04-18-2014, 09:26 AM
RE: Capacitor replacement question - by bfrohwein - 04-18-2014, 12:34 PM
RE: Capacitor replacement question - by tab10672 - 04-18-2014, 04:07 PM
RE: Capacitor replacement question - by Jamie - 04-20-2014, 08:49 AM
