Capacitor replacement question
I had one of those dual caps in my recent 624 restore.. it was even in a really annoyingly tight place under the antenna coil. I spaced out on how to replace it too! ;-)
Capacitor replacement question - by OldRestorer - 04-17-2014, 02:16 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 03:20 PM
RE: Capacitor replacement question - by exray - 04-17-2014, 05:58 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 07:10 PM
RE: Capacitor replacement question - by morzh - 04-17-2014, 09:33 PM
RE: Capacitor replacement question - by exray - 04-18-2014, 05:57 AM
RE: Capacitor replacement question - by tab10672 - 04-18-2014, 09:26 AM
RE: Capacitor replacement question - by bfrohwein - 04-18-2014, 12:34 PM
RE: Capacitor replacement question - by tab10672 - 04-18-2014, 04:07 PM
RE: Capacitor replacement question - by Jamie - 04-20-2014, 08:49 AM
