620b - worth it? (Bought it)
This 620B popped up on craigslist, and I'm going to Charlotte next weekend. I offered $50, he said he'd take $65. Is that worth it? I want a tombstone Philco, this one is in decent shape, but the electronics don't look like anything special.
http://charlotte.craigslist.org/atq/4428294651.html
Thanks!
Will
620b - worth it? (Bought it) - by skyscraper - 04-18-2014, 12:47 PM
RE: 620b - worth it? - by Mondial - 04-18-2014, 12:57 PM
RE: 620b - worth it? - by vinzer - 04-18-2014, 12:58 PM
RE: 620b - worth it? - by skyscraper - 04-18-2014, 01:36 PM
RE: 620b - worth it? - by Jayce - 04-18-2014, 01:45 PM
RE: 620b - worth it? - by Ron Ramirez - 04-18-2014, 03:52 PM
RE: 620b - worth it? - by skyscraper - 04-18-2014, 05:23 PM
RE: 620b - worth it? - by morzh - 04-18-2014, 06:16 PM
RE: 620b - worth it? - by skyscraper - 04-18-2014, 07:02 PM
RE: 620b - worth it? - by Eric Adams - 04-18-2014, 07:14 PM
RE: 620b - worth it? - by fegravel - 04-21-2014, 10:09 PM
RE: 620b - worth it? - by skyscraper - 04-21-2014, 11:07 PM
RE: 620b - worth it? - by fegravel - 04-21-2014, 11:13 PM
RE: 620b - worth it? - by skyscraper - 04-22-2014, 07:14 PM
RE: 620b - worth it? - by Ron Ramirez - 04-22-2014, 07:22 PM
RE: 620b - worth it? - by fegravel - 04-22-2014, 07:40 PM
RE: 620b - worth it? - by skyscraper - 04-22-2014, 07:40 PM
RE: 620b - worth it? - by skyscraper - 04-26-2014, 05:42 PM
Philco 91 Tuning Condenser
