620b - worth it? (Bought it)
If it's still there on the 26th, I'll get it. Thanks guys!
The reason I say that is I have several six tubers from the same era, so nothing out of the ordinary.
Will
620b - worth it? (Bought it) - by skyscraper - 04-18-2014, 12:47 PM
RE: 620b - worth it? - by Mondial - 04-18-2014, 12:57 PM
RE: 620b - worth it? - by vinzer - 04-18-2014, 12:58 PM
RE: 620b - worth it? - by skyscraper - 04-18-2014, 01:36 PM
RE: 620b - worth it? - by Jayce - 04-18-2014, 01:45 PM
RE: 620b - worth it? - by Ron Ramirez - 04-18-2014, 03:52 PM
RE: 620b - worth it? - by skyscraper - 04-18-2014, 05:23 PM
RE: 620b - worth it? - by morzh - 04-18-2014, 06:16 PM
RE: 620b - worth it? - by skyscraper - 04-18-2014, 07:02 PM
RE: 620b - worth it? - by Eric Adams - 04-18-2014, 07:14 PM
RE: 620b - worth it? - by fegravel - 04-21-2014, 10:09 PM
RE: 620b - worth it? - by skyscraper - 04-21-2014, 11:07 PM
RE: 620b - worth it? - by fegravel - 04-21-2014, 11:13 PM
RE: 620b - worth it? - by skyscraper - 04-22-2014, 07:14 PM
RE: 620b - worth it? - by Ron Ramirez - 04-22-2014, 07:22 PM
RE: 620b - worth it? - by fegravel - 04-22-2014, 07:40 PM
RE: 620b - worth it? - by skyscraper - 04-22-2014, 07:40 PM
RE: 620b - worth it? - by skyscraper - 04-26-2014, 05:42 PM
Philco 91 Tuning Condenser
There are currently 8934 online users. [Complete List]
» 2 Member(s) | 8932 Guest(s)
