Phono Cartridge
I have a 46-1256 radio phono and the phone only lets out a small
sound from the needle/cartridge but not from the speaker. The radio plays great through the speaker. Is the cartridge bad? if so where can I find a cartridge for a Philco radio/phonograph model 46-1256
Phono Cartridge - by lumberman22 - 04-18-2014, 11:02 PM
RE: Phono Cartridge - by NostalgiaRadioTime - 04-18-2014, 11:55 PM
RE: Phono Cartridge - by lumberman22 - 04-19-2014, 10:30 AM
RE: Phono Cartridge - by Chuck Schwark - 04-20-2014, 09:21 PM
RE: Phono Cartridge - by lumberman22 - 04-20-2014, 10:29 PM
Philco 91 Tuning Condenser
