Grill time! Making a replacement grill mold NEW PICS
Kirk ,
You might take a table at a swap meet or flea market and test the waters trying to sell a few of the ones that you don't want any longer.
Too bad our swap meet in New Hampshire is so far away. That would be an ideal spot to try . You might even find more to take home.
Henry
RE: Grill time! - by TimC - 02-27-2014, 09:55 PM
RE: Grill time! - by morzh - 02-27-2014, 10:49 PM
RE: Grill time! - by OldRestorer - 02-28-2014, 10:04 AM
RE: Grill time! Making a replacement grill mold at home - by radiohenry - 04-20-2014, 11:32 PM
Users browsing this thread: 16 Guest(s)
There are currently 10430 online users. [Complete List]
» 1 Member(s) | 10429 Guest(s)
