Philco PT-69 (Done), 38-62 (Done) & 41-22CL Resto Chronicles
#43
That's pretty close to what I am doing. After the last clear coat I use 320 to get any imperfections out , then go to 400 for a smoother finish and end up using 600, then 1000, 1500 and finally 2000 grit. I haven't waxed it yet but am planning on using the Johnsons Paste Wax also... I think that is the normal procedure for finishing . Sounds good.
I would be interested in seeing how you do veneer patches.
RE: Philco PT-69 (Done), 38-62 (Done) & 41-22CL Resto Chronicles - by Warren - 04-21-2014, 01:49 AM
There are currently 8667 online users. [Complete List]
» 4 Member(s) | 8663 Guest(s)
AvatarAvatarAvatarAvatar
