Photo Finish Restoration
Hey! That's lookin' good! Please post updates! I am no longer put off by cabinets with photo finish. If it's a simple stripe, it's much easier to restore than damaged veneer.
Photo Finish Restoration - by Jamie - 03-17-2014, 03:36 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:40 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:43 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:46 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:50 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:55 PM
RE: Photo Finish Restoration - by klondike98 - 03-17-2014, 04:34 PM
RE: Photo Finish Restoration - by OldRestorer - 03-17-2014, 05:56 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 06:23 PM
RE: Photo Finish Restoration - by shaler78 - 03-17-2014, 06:51 PM
RE: Photo Finish Restoration - by EricS - 03-29-2014, 07:17 PM
RE: Photo Finish Restoration - by Jamie - 03-30-2014, 08:26 AM
RE: Photo Finish Restoration - by klondike98 - 04-21-2014, 12:37 PM
RE: Photo Finish Restoration - by Jamie - 04-21-2014, 05:39 PM
Philco 91 Tuning Condenser
There are currently 8538 online users. [Complete List]
» 1 Member(s) | 8537 Guest(s)
