Philco 18B - New find
Nice find, should clean up well and everything is there including a little rodent stuff.
Jerry
Philco 18B - New find - by fegravel - 04-21-2014, 10:33 PM
RE: Philco 18B - New find - by jerryhawthorne - 04-21-2014, 11:43 PM
RE: Philco 18B - New find - by fegravel - 04-21-2014, 11:46 PM
RE: Philco 18B - New find - by OldRestorer - 04-22-2014, 06:39 AM
RE: Philco 18B - New find - by Steve Davis - 04-22-2014, 08:02 AM
RE: Philco 18B - New find - by fegravel - 04-22-2014, 08:51 AM
RE: Philco 18B - New find - by TA Forbes - 04-22-2014, 09:17 PM
Philco 91 Tuning Condenser
There are currently 5074 online users. [Complete List]
» 2 Member(s) | 5072 Guest(s)
