Nice pickup today !! Philco 50 Cathedral !!
Oh my, you appear to have found an early 50 at that! Shame about the speaker, though. Little kid damage I would say. I found a model 50 last fall, but it is the later version in its own style of cabinet.
Good luck on the house buyout tonight!
RE: Nice pickup today !! Philco 50 Cathedral !! - by Jayce - 04-22-2014, 02:12 PM
Philco 91 Tuning Condenser
