Grill time! Making a replacement grill mold NEW PICS
#32
Here is a complete list of Philco models using this grille, with color variations:
[Image: http://i326.photobucket.com/albums/k420/...g~original]
As you can see, several Philcos use this grille...and the majority of them used brown swirled Tenite.
The 41-221C, 41-221CI, 42-853 and 42-854 had "B'D'CST" and "S.W." embossed in the grille above the band switch knob.
[Image: http://www.philcoradio.com/gallery/image...1221ci.jpg]
The 41-226 had "P.B.", "B'D'CST" and "S.W." embossed in the grille above the band switch knob.
[Image: http://www.philcoradio.com/notebook/images/41226_b.jpg]
Decals would be an acceptable substitute, I think, and could be added by the buyers of these grilles to take care of that problem.
Looks great, Kirk! Icon_thumbup Icon_clap
RE: Grill time! - by TimC - 02-27-2014, 09:55 PM
RE: Grill time! - by morzh - 02-27-2014, 10:49 PM
RE: Grill time! - by OldRestorer - 02-28-2014, 10:04 AM
RE: Grill time! Making a replacement grill mold (what colors) - by Ron Ramirez - 04-22-2014, 04:09 PM
Users browsing this thread: 17 Guest(s)
