1st radio ever, Philco 37-640 restoration (DONE)
Great job! You have saved another from the Kutztown Cabinet bonfire...
RE: 1st radio ever, Philco 37-640 restoration (DONE) - by PhilcoJohn - 04-23-2014, 07:02 AM
Philco 91 Tuning Condenser
