Vibrator Cross Reference?
I would open it up and have a look, I bet the only thing wrong is the point need cleaning. I have done this many times with good results.
Gregb
Vibrator Cross Reference? - by bfrohwein - 04-22-2014, 08:23 PM
RE: Vibrator Cross Reference? - by Carl Travis - 04-23-2014, 03:43 PM
RE: Vibrator Cross Reference? - by K7Sparky - 04-23-2014, 04:14 PM
RE: Vibrator Cross Reference? - by gregb - 04-23-2014, 05:34 PM
RE: Vibrator Cross Reference? - by bfrohwein - 04-23-2014, 05:37 PM
RE: Vibrator Cross Reference? - by K7Sparky - 04-28-2014, 06:57 PM
RE: Vibrator Cross Reference? - by K7Sparky - 05-25-2014, 03:43 PM
RE: Vibrator Cross Reference? - by bfrohwein - 05-25-2014, 05:29 PM
RE: Vibrator Cross Reference? - by K7Sparky - 05-25-2014, 07:19 PM
RE: Vibrator Cross Reference? - by bfrohwein - 05-25-2014, 10:26 PM
RE: Vibrator Cross Reference? - by joybird - 05-27-2014, 03:32 PM
There are currently 11424 online users. [Complete List]
» 2 Member(s) | 11422 Guest(s)
