just got offered a huge haul!
well ask and ye shall receive. I was saying I never hit a score like some of you guys but I got an offer today from the relative of the head of CBS SOmething?
He has thousands of tubes and items from radios to ham stuff and military communication devices. He says a ton of it is still in boxes. He is going to start sending me emails and pictures and I will post them. hopefully it is not a crap fest.
just got offered a huge haul! - by OldRestorer - 04-24-2014, 12:59 PM
RE: just got offered a huge haul! - by PhilcoJohn - 04-24-2014, 07:11 PM
RE: just got offered a huge haul! - by TA Forbes - 04-25-2014, 10:38 AM
Philco 91 Tuning Condenser
